Software Archive
Read-only legacy content
17060 Discussions
Evaluation license error #10310: Failed to enable trusted storage check for licensing
alec-seward
I just installed the Intel Visual C++ Composer XE 2015 and have the problem described here: https://software.intel.com/en-us/articles/evaluation-license-error-10310....
Build is for X64.
It would be great if you could send me an evaluation license file to get around the issue.
Thank you very much,
Alec
Hubert_H_Intel
Hi Alec,
A more suitable workaround would be to invoke the Intel Compiler once with admin rights, e.g. as follows:
Run icl from a command prompt as Administrator via Start menu > Intel Parallel Studio 2015 > Compiler and Performance Libraries > Command Prompt with Intel Compiler > Intel 64 Visual Studio 2013 mode > (right-click) Run as administrator.
Regards, Hubert.
