Software Archive
Read-only legacy content
17060 Discussions
Examples using PXCProjection but not uvmap
James_T_2
Are there any examples where the Map and Project methods of  PXCProjection/PXCMProjection are used?
Preferable examples that go in a complete loop that checks the transforms are working in all directions.
I have only found examples using uvmap or its inverse.
Yuri_M_Intel
Hi James,
Please, try the 3DViewer is integrated into the CaptureViewer.
Start CaptureViewer, select any depth profile for display, click right mouse button on the selected, and press Start3DView from popup menu
James_T_2
I'll check that out when I get back to my camera, but I don't see the source code for CaptureViewer in the SDK.  Is that source code available somewhere else?
Xusheng_L_Intel
You can find the sample code @C:\Program Files (x86)\Intel\RSSDK\sample\raw_streams
James_T_2
projection.cpp in raw_streams uses MapDepthToColor so that is a good help.
Are there any examples that use the Projection methods?
samontab
Valued Contributor II
James_T_2
I'm blind, I can't find any reference to the Project methods of PXCProjection.
Here is what I see:
sample/raw_streams/src has 4 files.
main.cpp has no references to PXCProjection
projection.cpp references PXCProjection and calls:
    Release
    QueryUVMap
    MapDepthToColor
    CreateDepthImageMappedToColor
    QueryInvUVMap
raw_streams only calls PXCProjection via projection.cpp code, it has no references to PXCProjection
timer.cpp has no references to PXCProjection
Am I missing the calls or maybe there is a newer version than the code that gets installed with the Gold SDK?
samontab
projection.cpp is the one with the projections ;)
what else do you need?
James_T_2
Can you give me a line number where any of the ProjectXXX methods of PXCProjection are used?  I just can't find any.
If you really do see those methods being used, we must have different files.  I have the files that were installed with "intel_rs_sdk_offline_package_r_3.1.0.85181.exe"
The file "sample\raw_streams\src\projection.cpp" contains a reference to PXCProjection:MapDepthToColor on line 139.  This gets executed when you press the IDC_PROJECTION button in the UI of raw_streams.
I can't find a reference to any of the 4 ProjectXXX methods of PXCProjection in that file.
samontab
OK, I was refering to the general projection word, not the specific methods. You are right.
