Software Archive
Read-only legacy content
17060 Discussions
Exceptions in Parallel Studio 2013 XE
caosun
I use Parallel Studio 2013 XE in VS2010.
When I debug my program, there is one exception pop up: 0xA1A01DB1: Intel Parallel Debugger Extension Exception 1.
Intel said it is an known issue in VS2005, but I found it exists in VS2010.
Any solution on that?
bernaske
Hi under openSUSE 12.2 Linux ( x86_64) i have no problems with the IDB have you the sample source which makes the troubles ? can you post for a test ? cheers Franz
caosun
I use windows7 OS. Does anyone in Intel find the issue?
Brandon_H_Intel
Hello caosun, Composer XE 2013 no longer contains the Intel(R) Parallel Debug Extensions, so you likely still have them from a previous installed version. Can you uninstall that old version and see if the problem persists? Brandon
SergeyKostrov
Valued Contributor II
>>...Any solution on that? Please verify Visual Studio and your project settings. Set a default Microsoft's debugger if a different debugger is used.
caosun
Brandon Hewitt (Intel) wrote:
Hello caosun,
Brandon
Hi Brandon:
    I use Composer 2011 and VS2010 before and there is no such problem. Just when I install Compoer XE 2013, I saw this issue.
