Software Archive
Read-only legacy content
17060 Discussions
Expandable array, pointers and stack overflow
fela
In the following programme i try to make an "expandable array". When MXOSIZ=12 the line CXDATA(1:MXOSIZ)=CXTEMP causes a stack overflow. Why do I get a stack overflow? Can I structure my programme differently in order not to get a stack overflow? And is there a better way to make an "expandable" array.
PROGRAM GROW
IMPLICIT NONE
!  **** PARAMETERS ****
INTEGER(4),      PARAMETER :: MXDATL=100000
INTEGER(4),      PARAMETER :: MXGROW=2
!  **** VARIABLES ****
INTEGER(4)                 :: MXALLO
INTEGER(4)                 :: MXOSIZ
INTEGER(4)                 :: MXSTAT
INTEGER(4)                 :: MXLOOP
INTEGER(4)                 :: MXNREC
INTEGER(4)                 :: MXSIZE
INTEGER(4)                 :: MXINDX
CHARACTER(MXDATL), POINTER :: CXTEMP(:)
CHARACTER(MXDATL), POINTER :: CXDATA(:)
!  INITIALIZE.
MXNREC=0
MXSIZE=0
!  FILL DATA IN ARRAY.
DO MXLOOP=1,100
!  INCREASE THE NUMBER OF RECORDS BY ONE.
MXNREC=MXNREC+1
!  ALLOCATE MORE SPACE IF OUT OF SPACE.
IF (MXNREC.GT.MXSIZE) THEN
IF (MXSIZE.GT.0) THEN
CXTEMP=>CXDATA
PRINT*,SIZEOF(CXTEMP)
ENDIF
MXOSIZ=MXSIZE
MXSIZE=MXSIZE+MXGROW
ALLOCATE(CXDATA(MXSIZE),STAT=MXALLO)
IF (MXOSIZ.GT.0) THEN
CXDATA(1:MXOSIZ)=CXTEMP   !STACK OVERFLOW WHEN MXOSIZ=12
DEALLOCATE(CXTEMP,STAT=MXALLO)
ENDIF
ENDIF
!  SAVE THE RECORD.
CXDATA(MXNREC)='12345'
ENDDO
END
It would appear that the compiler is creating a stack temporary as part of the assignment, and it is exceeding the default 1MB stack allocation. I'm not sure why a temporary is used here - I do know that our removal of unnecessary temps isn't done as much for CHARACTER types as it is for numerics.
I'll pass this on to our experts in this area for their consideration.
Steve
