Software Archive
Read-only legacy content
17060 Discussions
External Links not working
Arwin_M_
I have app made in Construct 2. In the app preview on xdk, the external links are working fine. But after build and installed the apk on my mobile, the external links are not working anymore.
Arwin_M_
Swati_S_Intel1
Do you have whitelisting options set properly? What kind of external link are not working for you? See this article for how to set whitelisting rules in Intel XDK.
Arwin_M_
Hi this is my settings look like, I'm not sure where I have errors here. nav_0.JPG
Arwin_M_
Up please!
Swati_S_Intel1
Can you post the code you are using to open the external link (or send the project zip via PM)?
Arwin_M_
This is my code in construct 2. It's working in intel xdk app preview on my mobile. But not working after the build or apk is installed on device.. Thanks!
Anusha_M_Intel1
@Arwin, I don't see your code anywhere. I only see an image of your app UI.
Could you respond with the code snippet? Or if possible, message a zipped version of your project via PM (Send author a message).
Arwin_M_
I use construct 2 and that's the code above I posted.
Arwin_M_
I believe it has nothing to do with the code because in the "app preview" the external links are working.
Arwin_M_
fixed using http://*
