Software Archive
Read-only legacy content
17060 Discussions
External monitor problem intel GMA950
legomenon
I've an MSI 262 megabook with Intel GMA950 express chipset. When I connect my laptop to an external LG 782LE (native res: 1280X1024) the system allows me to set up max 1280x800 (which is the max of my laptop display). How can i set up the max resolution of the external lcd?
I've run the Moninfo but I got info only my laptop display:
Windows description......... Seiko-Epson Monitor
Manufacturer................ Seiko-Epson
Plug and Play ID............ SEC4241
Serial number............... n/a
EDID data source............ I2C bus (real-time)
Manufacture date............ 2005
EDID revision............... 1.3
Display type and signal..... Digital
Sync input support.......... n/a
Screen size................. 260 x 160 mm (~13")
Power management............ n/a
Color characteristics
Display gamma............... 2,20
Red chromaticity............ Rx 0,580 - Ry 0,340
Green chromaticity.......... Gx 0,310 - Gy 0,550
Blue chromaticity........... Bx 0,155 - By 0,155
White point (default)....... Wx 0,313 - Wy 0,329
Timing characteristics
VESA GTF support............ Not supported
Horizontal scan range....... n/a
Vertical scan range......... n/a
Video bandwidth............. n/a
Extension blocks............ n/a
Timing recommendation #1.... 1280x800 at 60Hz
Modeline................ "1280x800" 68,940 1280 1296 1344 1408 800 801 804 816 -hsync -vsync
Standard timings supported
n/a
Raw EDID base
00: 00 FF FF FF FF FF FF 00 4C A3 41 42 00 00 00 00
10: 00 0F 01 03 80 1A 10 78 0A 87 F5 94 57 4F 8C 27
20: 27 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
30: 01 01 01 01 01 01 EE 1A 00 80 50 20 10 30 10 30
40: 13 00 05 A3 10 00 00 19 00 00 00 0F 00 00 00 00
50: 00 00 00 00 00 23 87 02 64 00 00 00 00 FE 00 53
60: 41 4D 53 55 4E 47 0A 20 20 20 20 20 00 00 00 FE
70: 00 4C 54 4E 31 32 31 57 31 2D 4C 30 33 0A 00 E2
Display adapter
Adapter description......... Auxiliary port
Adapter device ID........... 0x27A68086
Display settings............ n/a
Aaron_B_Intel
Are you connecting the monitor through a docking station or direct to the laptop? Sometimes connecting directly to the laptop will result in MonInfo working better. I'll look around for some generic 1280x1024 DTDs for you. Surprised those don't show up when "Hide All Modes" is unchecked, though...
legomenon
Thanks for the fast response!
The monitor is connected directly to the laptop. But something is very strange for me, when I am using only the laptop's screen I can setup almost all resolutions but when only the external monitor is active the resolution set is limited and the 1280x1024 is not on the list.
Aaron_B_Intel
I'd try generic 1280x1024:
8C 23 00A0 50 001E 40 30 20 27 00 00 00 00 00 00 1E
Use the Wiki to set this up (don't forget to comma delimit and add ",37,01" to the end), reboot, and you should get this resolution as an option. If not, check whether all the registry "DTD_1" values are being populated withthat hex string I gave and whether "TotalDTDs" (or whatever thevariable name is)is>0.If the registry is okay and you're still not getting it to show up, it might be the VideoBIOS prohibiting it; try 1278x1024:
8C 23FEA2 40 001E 40 30 20 27 00 00 00 00 00 00 1E
