Software Archive
Read-only legacy content
17060 Discussions
F200 R2 SDK All Samples not working
GMele
Hi I just upgraded to the R2 SDK and it seems now all the sames are no longer working... I initially noticed in the webruntime but found that it happens for all samples (C#, C++, and JavaScript) on the F200. It all seems to have something to do with the PXCMSenseManager module but I can't quite nail it down.
The most detail I've gotten for the error is in the eventlog entry below, but I also tried to debug the C# FF_HandsViewer.csproj and in the HandsRecognition.cs file, it chokes on the line where it tries to get the frame
line 952
if (instance.AcquireFrame(true) < pxcmStatus.PXCM_STATUS_NO_ERROR)
where "instance" is an instance of the PXCMSenseManager. Up to that point, the camera is active and instance.IsConnected() equals true but after calling AcquireFrame it just dies and I can't debug and deeper than that.
If I let it run ourside the IDE, this is what goes into the error log:
Application: Capability.Servicer.RealSense.v10.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
   at PXCMSenseManager.PXCMSenseManager_PauseModule(IntPtr, Int32, Boolean)
   at RPC_PXCMSenseManager.PXCMSenseManager_PauseModule(DataSet, DataSet)
Exception Info: System.Reflection.TargetInvocationException
   at System.RuntimeMethodHandle.InvokeMethod(System.Object, System.Object[], System.Signature, Boolean)
   at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(System.Object, System.Object[], System.Object[])
   at System.Reflection.RuntimeMethodInfo.Invoke(System.Object, System.Reflection.BindingFlags, System.Reflection.Binder, System.Object[], System.Globalization.CultureInfo)
   at Responser.ProcessMessage(DataSet)
   at Responser.OnTextReceived(System.Object, System.Object, System.String)
   at PXCWebSocketITAServer.OnNewMessageReceived(System.Object, Intel.Technology.Access.Capability.Servicer.Interface.ClientRequest)
   at Intel.Technology.Access.Capability.Servicer.Interface.Communication+<Read>d__e.MoveNext()
   at System.Runtime.CompilerServices.AsyncMethodBuilderCore+MoveNextRunner.InvokeMoveNext(System.Object)
   at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Runtime.CompilerServices.AsyncMethodBuilderCore+MoveNextRunner.Run()
   at System.Threading.Tasks.AwaitTaskContinuation.RunOrScheduleAction(System.Action, Boolean, System.Threading.Tasks.Task ByRef)
   at System.Threading.Tasks.Task.FinishContinuations()
   at System.Threading.Tasks.Task.FinishStageThree()
   at System.Threading.Tasks.Task`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].TrySetResult(System.__Canon)
   at System.Runtime.CompilerServices.AsyncTaskMethodBuilder`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].SetResult(System.__Canon)
   at Intel.Technology.Access.Capability.Servicer.Interface.Communication+<Receive>d__13.MoveNext()
   at Intel.Technology.Access.Capability.Servicer.Interface.Communication+<ReadMessage>d__21.MoveNext()
   at System.Threading.Tasks.Task`1[[System.Int32, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].TrySetResult(Int32)
   at System.Threading.Tasks.TaskFactory`1+FromAsyncTrimPromise`1[[System.Int32, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].Complete(System.__Canon, System.Func`3<System.__Canon,System.IAsyncResult,Int32>, System.IAsyncResult, Boolean)
   at System.Threading.Tasks.TaskFactory`1+FromAsyncTrimPromise`1[[System.Int32, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].CompleteFromAsyncResult(System.IAsyncResult)
   at System.IO.Stream+ReadWriteTask.InvokeAsyncCallback(System.Object)
   at System.IO.Stream+ReadWriteTask.System.Threading.Tasks.ITaskCompletionAction.Invoke(System.Threading.Tasks.Task)
   at System.Threading.Tasks.Task.FinishStageTwo()
   at System.Threading.Tasks.Task.Finish(Boolean)
   at System.Threading.Tasks.Task.ExecuteWithThreadLocal(System.Threading.Tasks.Task ByRef)
   at System.Threading.Tasks.Task.ExecuteEntry(Boolean)
   at System.Threading.Tasks.Task.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
   at System.Threading.ThreadPoolWorkQueue.Dispatch()
   at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
