Software Archive
Read-only legacy content
17060 Discussions
Facebook Connect plugin not working
David_B_12
Hello,  I've build an app using the Facebook connect plugin for Cordova Hybrid Android.
There's nowhere to set the facebook application signature like in the legacy credentials tab.
I read on another topic that you have to email support (which I did 3 days ago, and not received a reply) to get the facebook key so I'm now stuck.
Also, is there there not any way to debug an app that uses facebook connect?  It seems like a serious restriction if you can't.  It seems the emulator nor debyg in XDK can't do it :(
Amrita_C_Intel
Only the Build tab actually uses third-party (non-core) plugins. Future editions of the Intel XDK will expand the use of third-party plugins throughout the development cycle. However, at this time the only way you can test and debug any code in your app that accesses third-party plugins is to build an application and run it on a real device.
Please use this link to learn more about debugging third party plugin app
https://software.intel.com/en-us/xdk/docs/adding-third-party-plugins-to-your-xdk-cordova-app
And for Facebook Connect plugin you cannot use legacy procedure in order to make it work. Please follow the below article.
https://software.intel.com/en-us/xdk/article/facebook-connect-plugin-android-ios
Let me know if you have any further questions.
