Software Archive
Read-only legacy content
17060 Discussions
Facebook Sample doesn't work more
Caio_d_
The probblem occurs when I go debug or build the application, below I have attached some pictures about build and plugins configuration. This problem started after the March update of Intel XDK.
BUILD FAILED
Build Log
  • Building a Cordova 5.1.1 application.
  • Using platform cordova-android 4.1.1.
  • The application name is "last_test"
  • The package name is "xdk.sample.facebookConnect"
  • Preference android-signed set to true. Application will be signed.
  • Using Crosswalk Embedded 15
  • Plugin "cordova-plugin-statusbar" (2.0.0) installed.
  • Plugin "cordova-plugin-device" (1.1.0) installed.
  • Plugin "cordova-plugin-splashscreen" (2.1.0) installed.
  • Error: Plugin Facebook Connect failed to install.
  • Plugin "cordova-plugin-legacy-whitelist" (1.1.1) installed.
  • Plugin "cordova-plugin-crosswalk-webview" (1.4.0) installed.
OBS: In the past i used this sample normally and now I'm facing difficulties.
OBS²: I tried this following topics to fix it:
https://software.intel.com/pt-br/forums/intel-xdk/topic/622006?language=es
https://software.intel.com/pt-br/forums/intel-xdk/topic/622356
502405
daniel_p_3
Hey, i'm having exactly the same problem. After the update, everytime i try to build the application i have this error. Can someone help us please? ThankYou!
PaulF_IntelCorp
The sample has been updated, please try again with the updated sample.
Caio_d_
Hi Paul, the issue still occurring at the same fail message.
PaulF_IntelCorp
Caio -- are you still experiencing a build issue? You need to uninstall that old facebook plugin and install the "facebook4" plugin.
