Software Archive
Read-only legacy content
17060 Discussions
Fails to integrage Intel Composer with MS VS2005
jesperthygesen
I have installed Intel Composer XE 2011 Update 8 for Windows (file: w_ccompxe_2011.8.278.exe).
The installation package automatically detected I had Microsoft Visual Studio 2005 installed, and choose to integrate with it.
When starting VS2005 i get the following error stated below, any idea how to fix this?
/Jesper
Package Load Failure
Package 'Intel C++ Compiler Integration Package, Property Pages' has failed to load properly ( GUID = {D6EEEC80-45EA-4CA7-AE30-74700CA09F81} ). Please contact package vendor for assistance. Application restart is recommended, due to possible environment corruption. Would you like to disable loading this package in the future? You may use 'devenv /resetskippkgs' to re-enable package loading.
Yes No
Rob5
New Contributor II
Jesper,
Do the steps outlined in the forum thread here resolve the issue?
- Rob
jesperthygesen
Thanx for the fast reply.
Unfortunately the files of Composer XE 2011 differs alot from those of Composer 2009 for which the linked to thread was written. I have no integrate.bat file in my installation.
The closest thing is "C:\Program Files (x86)\Intel\Composer XE 2011 SP1\VS Integration\C++\VS2005\InstallMnu.bat", but it doesn't register any dlls.
/Jesper
Content of InstallMnu.bat
@echo off
setlocal
if defined programfiles(x86) SET programfiles=%programfiles(x86)%
SET VSINSTALLDIR=%ProgramFiles%\Microsoft Visual Studio 8
SET VS_BVER=8.0
SET PROD=CompPro
SET PWD=%~dp0
cscript //NoLogo "RegReplace.vbs" "\[SystemFolder\]" "%windir%\system32" True False < "ICMnuPkg.%PROD%.regx" > "tmp1.reg"
cscript //NoLogo "RegReplace.vbs" "\[INSTALLDIR\]" "%PWD%" True False < "tmp1.reg" > "tmp2.reg"
cscript //NoLogo "RegReplace.vbs" "" "%VS_BVER%" False False < "tmp2.reg" > "tmp1.reg"
del tmp2.reg
SET REGEDIT_DIR=%WINDIR%
if defined programfiles(x86) SET REGEDIT_DIR=%WINDIR%\SysWOW64
%REGEDIT_DIR%\regedit /s tmp1.reg
del tmp1.reg
"%VSInstalldir%\Common7\IDE\devenv.exe" /setup /noVSIP
IDZ_A_Intel
Jesper,
Perhaps someone in the compiler group can assist here. If you have not done so already, it is possible a reboot may change the behavior. Also, there are some important notes in the Update 8 Intel C++ Composer XE 2011for Windows* Installation Guide and Release Notes linked here relating to Visual Studio 2005.
For example, in section 2.2.6 there is an important reference to Prompt for Administrator Permission with Microsoft Visual Studio 2005*. If the dialog is missed or dismissed incorrectly the integration will fail. Might this be a possible cause?
You may also be able to use the Windows* Un-install / Change / Modify in the control panel to Modify (remove / add) the Compiler integration component for Visual Studio 2005. In Modify see the Integration(s) in Microsoft Visual Studio* tree node.
If the behavior persists, are you running as Administrator or user with less than Admin privs. You may want to post the operating system version and patch level you are running and possibly more information about the circumstances surrounding your install. For example, was a prior version of the compiler installed / integrated on this machine before or is this a new installation of the compiler?
- Rob
