Software Archive
Read-only legacy content
17060 Discussions
Firebase plugin, Gradle etc.
Doddo_D_
I try to install this plugin: https://github.com/arnesson/cordova-plugin-firebase
But when I compile the app on Android, I get the famous "Gradle error"...
I tried to comment the line
<framework src="src/android/build.gradle" custom="true" type="gradleReference" />
(following this: https://github.com/phonegap/phonegap-plugin-push/blob/master/docs/PHONEGAP_BUILD.md) ;
But I got this error:
http://pastebin.com/fScWtzu9
I also included the google-services.json file and .plist (IOS).
I really need Firebase for notifications and analytics...
I tried OneSignal and Google Analytics plugins, but there a conflict with "gms" (can't remmember the exact conflict)
Does anybody knows an issue ?
Diego_Calp
Valued Contributor I
XDK not support gradle scripts.
You may use Firebase without the plugin, check this doc:
https://firebase.google.com/docs/web/setup
Read WEB tab (not NODE.JS)
Diego
Diego_Calp
Diego
Doddo_D_
Thanks for your reply, I'll check it :)
Doddo_D_
Analytics don't works on web based apps, am I right ?
Diego_Calp
