Software Archive
Read-only legacy content
17060 Discussions
Flashcard Example doesn't work (Problem Solved)
Roy_F_
There's an example of the 'Flashcard Speech Recognition" by Bryan B. When you build the example there's a small code change that you have to make or else nothing will happen.
Find the line:-
status = speechRecognition.StartRec(null, handler);
if should be:-
status = speechRecognition.StartRec(audioSource, handler);
Bryan_B_Intel1
Thanks Roy, I'll look into this ASAP. -Bryan
Bryan_B_Intel1
Hi Roy,
I wanted to follow-up on your observation. If the audio source is omitted in StartRec, the SDK uses the default audio input device. After retesting the Flashcard sample with the latest SDK release, I found it works OK if you pass null or audioSource. I'm not sure why passing null is not working for you.
Thanks, Bryan
