Software Archive
Read-only legacy content
17060 Discussions
Force 60 fps
David_L_10
SR300 is supposed to be capable of 60 fps at varying resolutions up to 720p.
However, the camera exposure is handled automatically by the drivers so whenever the device is used in a medium to low light environment, the FPS drops dramatically no matter what it is set at. However, if I point the camera at a light source, for example my laptop screen or a lamp, the FPS rises back up to 60 regardless since the exposure setting will not be as high.
How can I force 60 fps regardless of setting/situation?
samontab
Valued Contributor II
You can't. That's how physics work.
If you need to expose for a second for example, you will get at most 1 frame per second.
If you mean disabling auto exposure, sure, you can do that, and set your own exposure time.
David_L_10
I am aware of how exposure works, but the exposure slider is very rough and only has a few ticks on the slider. It's too dark at the value where it begins to produce 60 fps, even when auto is able to have a higher setting and still return 60fos
samontab
You can set the exposure through their API. Don't use the GUI.
Also, put more lights in the scene.
