Software Archive
Read-only legacy content
17060 Discussions
Fortran Calling C Offloaded Function
Silva__Rafael
Hi Guys,
  I would like to know if it is possible to do a code like this:
!dir$ offload begin target (mic:0)
call C_SUBROUTINE(x, y)
!dir$ end offload
Where the subroutine code is:
__attribute__ ((target(mic:0)))
void c_subroutine_(float * __restrict x, float * __restrict y)
Where x and y are arrays of floats. I've tried but I'm getting invalid pointer error when the subroutine is called, even including "!dir$ attributes offload:mic :: C_SUBROUTINE" inside the calling Fortran subroutine.
Vidura_Dhananjaya
New Contributor II
Just try them from ints again
Silva__Rafael
Diko, I'm not sure I understood you suggestion. Do you mean to use integers? But I need floats, do it with integers does not solve my problem.
Kevin_D_Intel
Here is a short example.
example.f90:
program example_F_call_C
   USE ISO_C_BINDING
   USE MIC_LIB
   integer (C_INT) :: length = 5
   real (C_FLOAT)  :: answer = 0.0
   real (C_FLOAT), dimension(:), allocatable, target :: A, B
   interface
     real (C_FLOAT) function dotprod(length,A,B) bind(C,name="dotprod")
        USE ISO_C_BINDING
        integer (C_INT), VALUE :: length
        TYPE (C_PTR), VALUE :: A, B
     end function
   end interface
   ALLOCATE(A(length),B(length))
   do i = 1, length
      A(i) = REAL(i)
      B(i) = REAL((length+1) - i)
   end do
   ! calculate dot product of A and B
   !DIR$ ATTRIBUTES OFFLOAD : MIC :: dotprod
   !DIR$ OFFLOAD BEGIN target(mic) mandatory
       print "(A,i1)","Calc on card: ",OFFLOAD_GET_DEVICE_NUMBER()
       answer = dotprod(length, C_LOC(A), C_LOC(B))
   !DIR$ END OFFLOAD
   print "(F4.1)", answer
   do i = 1, length
      print "(F3.1,1x,F3.1)", A(i),B(i)
   end do
   DEALLOCATE(A,B)
end
dotprod.c:
__attribute__ ((target (mic)))
float dotprod(  int length, float *A, float *B )
    int i;
    float answer;
    answer = 0.0;
    for (i=0; i < length; i++) {
      answer += *(A+i) * *(B+i);
    return answer;
Build and execute as follows:
$ ifort -V
Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.1.133 Build 20141023
$ icc -V
Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.1.133 Build 20141023
$ icc -c dotprod.c
$ ifort example.f90 dotprod.o -o example.exe
$ ./example.exe
Calc on card: 0
35.0
1.0 5.0
2.0 4.0
3.0 3.0
4.0 2.0
5.0 1.0
Silva__Rafael
Thank you very much guys. I found the problem. In my software the Intel libraries where deployed together with our executable. So, for some reason, something conflict when tried to load the Intel libraries when launching the offloaded code. When I stopped deploying then, the problem was solved. As I'm still in a evaluation phase, I don't care about not deploying them, but in the future, this is something I would have to take care.
Kevin_D_Intel
Glad you have your code working. Let us know if you still face problems deploying w/Intel libraries in the future and we will help you resolve that.
