Software Archive
Read-only legacy content
17060 Discussions
Fortran common block and Modules
Dhanashree_G_
Hello sir,
I am converting one of the old code F77 in F90. I am encountering a huge number of errors, especially in common block and module.
I tried it in 3 ways by reading the forum information
1) I tried to make a static library of module object files but still, I was getting errors that showed that the static library is not linked properly with source files.
2)  I tried to execute the FORTRAN files of modules in source and it also didn't work.
3) I tried to keep the common blocks as it is and still it doesn't work at all.
I am giving a sample bit of one program:-
one file from the source files:-
SUBROUTINE arco(i,flow,*)
use  param1
use  parampch
use  array2
use  flag
use  CONSTNT
use  factlim
use  array1
use  options1
! Code converted using TO_F90 by Alan Miller
! Date: 2017-06-01  Time: 21:33:28
IMPLICIT NONE
INTEGER, INTENT(IN OUT)                  :: i
REAL, INTENT(IN)                         :: flow
!integer:: nsubr,ji2,kopt,ji1
!real:: rholim,dp(5000),area(5000)
!INTENT(IN)                               :: *
!    <NAME>
!     ARCO
!    <DESCRIPTION>
!     THIS SUBROUTINE CALCULATES THE FLOW VARIABLES ACROSS
!     AN ABRUPT AREA CHANGE.
INTEGER :: ik
REAL    :: rho1, fflow, beta2, rkf, phsq, phisq
IF(nsubr == 1)THEN
  rho(i,ji2) = rho(i-1,ji2)
  fflow      = flow
ELSE
  fflow      = rho(i-1,ji2)*u(i-1,ji2)*area(i-1)
  rho(i,ji2) = rho(i,ji1)
END IF
DO  ik=1,500
  u(i,ji2)   = fflow/area(i)/rho(i,ji2)
!------EXPANSION---------------------
  IF(area(i-1) < area(i))THEN
    beta2 = area(i-1)/area(i)
    rkf = (1.- beta2)**2
  ELSE
!------CONTRACTION-------------------
    beta2 = area(i)/area(i-1)
    rkf = 0.5*(1.-beta2 )/beta2**2
  END IF
!         Function PHISQ requires two parameters, assume JI2 is
!         the second parameter
  phsq = phisq(i-1,ji2)
  rkf = rkf*phsq*rho(i-1,ji2)/rhof(i-1,ji2)
  rkf = rkf * kopt
  p(i,ji2)    = p(i-1,ji2)+2.*fflow*((1.-rkf/2.)*u(i-1,ji2)-  &
      u(i,ji2))/(area(i-1)+area(i))
  h(i,ji2)    = h(i-1,ji2) + 0.5*(u(i-1,ji2)**2-u(i,ji2)**2)
  CALL stprop(p(i,ji2),h(i,ji2),i,rho1)
  IF( ik > 1 .AND. ABS(rho1-rho(i,ji2)) < rholim)THEN
    GO TO 200
  ELSE
    rho(i,ji2) = rho1
  END IF
END DO
200   CONTINUE
rho(i,ji2) = rho1
alfa(i,ji2)= xqu(i,ji2)*rho1/rhog(i,ji2)
alfa(i,ji2)= MAX(0.,alfa(i,ji2))
dp(i-1)    = p(i,ji2) - p(i-1,ji2)
RETURN
300   CONTINUE
RETURN 1
END SUBROUTINE arco
The modules used in the program are as follows
Module array1
use param1
use parampch
INTEGER :: ncode(nodemx), ncorsb(nodemx)
Real :: area(nodemx),   di(nodemx),     dx(nodemx),                &
    eqdiam(nodemx), v(nodemx),      rk(nodemx),                      &
    ck(nodemx),ruff(nodemx),dp(nodemx),vstar(nodemx),rstar(nodemx),  &
    sth(nodemx),sq(nodemx), nb(nodemx), &
    farray(nodemx)
real::burnpow
Real:: sumdxch(nodemx,nchanx) , fa(nodemx,nchanx)
integer:: ji1,ji2
End Module array1
Param1 and parampch modules have the variables "nodemx ", "nchanx" declared as parameters.
Dhanashree_G_
The error blog for perticular file is
ifort /nologo /debug:full /real_size:64 /Qsave /iface:cvf /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:static /threads /dbglibs /c /Qvc9 /Qlocation,link,"c:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\bin" "C:\Users\dhana\Desktop\All files together\Source\arco.f90"
C:\Users\dhana\Desktop\All files together\Source\arco.f90(5): error #7013: This module file was not generated by any release of this compiler.   [PARAM1]
use  param1
C:\Users\dhana\Desktop\All files together\Source\arco.f90(46): error #6404: This name does not have a type, and must have an explicit type.   [NSUBR]
IF(nsubr == 1)THEN
C:\Users\dhana\Desktop\All files together\Source\arco.f90(47): error #6410: This name has not been declared as an array or a function.   [RHO]
C:\Users\dhana\Desktop\All files together\Source\arco.f90(50): error #6404: This name does not have a type, and must have an explicit type.
C:\Users\dhana\Desktop\All files together\Source\arco.f90(50): error #6404: This name does not have a type, and must have an explicit type.   [AREA]
C:\Users\dhana\Desktop\All files together\Source\arco.f90(51): error #6410: This name has not been declared as an array or a function.   [RHO]
C:\Users\dhana\Desktop\All files together\Source\arco.f90(56): error #6410: This name has not been declared as an array or a function.
C:\Users\dhana\Desktop\All files together\Source\arco.f90(68): error #6404: This name does not have a type, and must have an explicit type.   [JI2]
C:\Users\dhana\Desktop\All files together\Source\arco.f90(69): error #6404: This name does not have a type, and must have an explicit type.   [RHOF]
C:\Users\dhana\Desktop\All files together\Source\arco.f90(70): error #6404: This name does not have a type, and must have an explicit type.   [KOPT]
  rkf = rkf * kopt
C:\Users\dhana\Desktop\All files together\Source\arco.f90(71): error #6410: This name has not been declared as an array or a function.
p(i,ji2) = p(i-1,ji2)+2.*fflow*((1.-rkf/2.)*u(i-1,ji2)- & --^ C:\Users\dhana\Desktop\All files together\Source\arco.f90(73): error #6410: This name has not been declared as an array or a function. h(i,ji2) = h(i-1,ji2) + 0.5*(u(i-1,ji2)**2-u(i,ji2)**2) --^ C:\Users\dhana\Desktop\All files together\Source\arco.f90(76): error #6404: This name does not have a type, and must have an explicit type. [RHOLIM] IF( ik > 1 .AND. ABS(rho1-rho(i,ji2)) < rholim)THEN ------------------------------------------^ C:\Users\dhana\Desktop\All files together\Source\arco.f90(79): error #6410: This name has not been declared as an array or a function. [RHO] rho(i,ji2) = rho1 ----^ C:\Users\dhana\Desktop\All files together\Source\arco.f90(84): error #6410: This name has not been declared as an array or a function. [RHO] rho(i,ji2) = rho1 ^ C:\Users\dhana\Desktop\All files together\Source\arco.f90(85): error #6410: This name has not been declared as an array or a function. [ALFA] alfa(i,ji2)= xqu(i,ji2)*rho1/rhog(i,ji2) ^ C:\Users\dhana\Desktop\All files together\Source\arco.f90(85): error #6404: This name does not have a type, and must have an explicit type. [XQU] alfa(i,ji2)= xqu(i,ji2)*rho1/rhog(i,ji2) -------------^ C:\Users\dhana\Desktop\All files together\Source\arco.f90(85): error #6404: This name does not have a type, and must have an explicit type. [RHOG] alfa(i,ji2)= xqu(i,ji2)*rho1/rhog(i,ji2) -----------------------------^ C:\Users\dhana\Desktop\All files together\Source\arco.f90(86): error #6410: This name has not been declared as an array or a function. [ALFA] alfa(i,ji2)= MAX(0.,alfa(i,ji2)) ^ C:\Users\dhana\Desktop\All files together\Source\arco.f90(86): error #6363: The intrinsic data types of the arguments must be the same. [MAX] alfa(i,ji2)= MAX(0.,alfa(i,ji2)) --------------------^ C:\Users\dhana\Desktop\All files together\Source\arco.f90(87): error #6410: This name has not been declared as an array or a function. [DP] dp(i-1) = p(i,ji2) - p(i-1,ji2) ^ compilation aborted for C:\Users\dhana\Desktop\All files together\Source\arco.f90 (code 1)
