Software Archive
Read-only legacy content
17060 Discussions
GEOLOCATION IOS
Emre_C_1
Dear all,
I've created an application to get user position via below functions.
It's working on Intel XDK and Android App preview but does not working on IOS app preview.
It mus be related with permissions but I didn't find a solution.
function initiate_geolocation() {
            navigator.geolocation.getCurrentPosition(handle_geolocation_query);
 function handle_geolocation_query(position){
            alert('Lat: ' + position.coords.latitude + ' ' +
                    'Lon: ' + position.coords.longitude);
My IOS config file.
<?xml version='1.0' encoding='UTF-8'?>
<widget xmlns="http://www.w3.org/ns/widgets" xmlns:intelxdk="http://xdk.intel.com/ns/v1" id="xdk.intel.blank.ad.template" version="0.0.1">
<!--This file is generated by the Intel XDK. Do not edit this file as your edits will be lost.           -->
<!--To change the contents of this file, see the documentation on the intelxdk.config.additions.xml file.-->
<intelxdk:version value="1.0"/>
<intelxdk:cordova-cli version="4.1.2"/>
<name>GEOTEST</name>
<description>Template to develop a Cordova mobile web app using the App Designer UI editor.</description>
<author>Intel XDK</author>
<content src="index.html"/>
<access origin="*"/>
<intelxdk:plugin intelxdk:name="Device" intelxdk:value="org.apache.cordova.device" intelxdk:version="0.2.13"/>
<intelxdk:plugin intelxdk:name="SplashScreen" intelxdk:value="org.apache.cordova.splashscreen" intelxdk:version="0.3.5"/>
<preference name="ios-target" value="6"/>
<preference name="ios-configuration" value="adhoc"/>
<!--creationInfo:{"src":"appDesigner","projectTypeName":"com.intel.xdk.projecttype.jsapp"}-->
<preference name="debuggable" value="false"/></widget>
Emre_C_1
John thanks for your reply.
I've finally solved it, it's about IOS Apppreview location permission.
John_H_Intel2
When you launched your app, did it prompt you to allow the app to use your location?
Emre_C_1
pedro_v_
I have the same problem. App works well in Intel XDK Preview, but when not built in Ios app and testing on a Iphone
PaulF_IntelCorp
Pedro -- is your problem with geolocation or something else? Please start a new thread, I'm closing this one because it is not clear if you issue is related to this one or something different.
