Software Archive
Read-only legacy content
17060 Discussions
Getting 1918 x 1200 on 915GM - Sony Vaio FJ170B and I-Inc iF281
nsbradley
I have a Sony VAIO laptop VGN-FJ170B (PCG-7F1L). It uses the Mobile Intel 915GM/GMS,910GML Express Chipset Family. I have a 28" I-Inc iF281D monitor. It can display 1920 x 1200 when connected to another PC. However, when connected to the laptop, the maximum resolution I can get is 1600 x 1200.
According to other threads, the Sony blocks 1920 x 1200. The Intel Graphics Driver report is listed below.
Could someone tell me the DTD code for 1918 x 1200?
Thank you.
Intel Graphics Media Accelerator Driver for Mobile Report
Report Date: 03/17/2009
Report Time[hr:mm:ss]: 13:44:13
Driver Version: 6.14.10.4764
Operating System: Windows XP* Professional, Service Pack 3 (5.1.2600)
Default Language: English
DirectX* Version: 9.0
Physical Memory: 2038 MB
Minimum Graphics Memory: 8 MB
Maximum Graphics Memory: 128 MB
Graphics Memory in Use: 17 MB
Processor: x86 family 6 Model 13 Stepping 8
Processor Speed: 1862 MHZ
Vendor ID: 8086
Device ID: 2592
Device Revision: 03
* Accelerator Information *
Accelerator in Use: Mobile Intel 915GM/GMS,910GML Express Chipset Family
Video BIOS: 1220
Current Graphics Mode: 1280 by 800 True Color (60 Hz)
* Devices Connected to the Graphics Accelerator *
Active Monitors: 1
Active Notebook Displays: 1
* Monitor *
Monitor Name: Plug and Play Monitor
Display Type: Analog
Gamma Value: 2.20
DDC2 Protocol: Supported
Maximum Image Size: Horizontal: 23.0 inches
Vertical: 14.0 inches
Monitor Supported Modes:
640 by 480 (60 Hz)
640 by 480 (67 Hz)
640 by 480 (72 Hz)
640 by 480 (75 Hz)
720 by 400 (70 Hz)
800 by 600 (56 Hz)
800 by 600 (60 Hz)
800 by 600 (72 Hz)
800 by 600 (75 Hz)
832 by 624 (75 Hz)
1024 by 768 (60 Hz)
1024 by 768 (70 Hz)
1024 by 768 (75 Hz)
1152 by 864 (75 Hz)
1152 by 870 (75 Hz)
1280 by 960 (60 Hz)
1280 by 1024 (60 Hz)
1280 by 1024 (75 Hz)
1400 by 1050 (60 Hz)
1440 by 1440 (60 Hz)
1600 by 1200 (60 Hz)
1680 by 1680 (60 Hz)
1920 by 1200 (60 Hz)
1920 by 1920 (60 Hz)
Display Power Management Support:
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
* Notebook *
Monitor Name:
Display Type: Digital
Gamma Value: 3.54
Maximum Image Size: Horizontal: Not Available
Vertical: Not Available
1280 by 800 (60 Hz)
Standby Mode: Not Supported
Suspend Mode: Not Supported
* SDVO Encoder Report *
** Encoder 1 **
Vendor ID: Silicon Image
Device ID: 170
Device Revision: 2
Major Version: 1
Minor Version: 0
* Other names and brands are the property of their respective owners.
Aaron_B_Intel
The DTD is
28 3C 7E A2 70 B0 23 40 32 20 36 00 51 73 21 00 00 1A
nsbradley
Thank you very much. This worked perfectly.
