Software Archive
Read-only legacy content
17060 Discussions
Getting errors when using Intel COmpiler in Visual Studio 2012+how to use Intel TBB
Arvind_D_
Hi
I am using Intel Parallel Studio XE 2013. In VS2012. I am creating some basic code to use Intel TBB.
However I am getting some basic errors-
(1) Error- cannot open source file iostream.h - Statement= #include <iostream.h>
(2) String *StringValue - Error:Identifier String is undefined.
How do I solve above errors. In VS I have activated Intel Compiler using options Project-> Intel Composer XE 2013-> Use Intel C++
(3) How do I use Intel TBB library in my project above?
(4) In Concurrent hashmap example in Intel TBB docs, cstr is used for hashmap of string- can I use cstr for hashmap of integers and double and float as well.
Yours sincerely,
Arvind.
SergeyKostrov
Valued Contributor II
>>(1) Error- cannot open source file iostream.h - Statement= #include >> >>(2) String *StringValue - Error:Identifier String is undefined. I think first two errors are related and use iostream instead of iostream.h. It also makes sense to verify if iostream.h exists in VS 2012 Include directory.
VADIM_G_Intel
Hi Arvind,
To use Intel TBB in your C++ project do the following: Open project properties dialog, "Configuration Properties -> Intel Performance Libraries" and set "Use Intel TBB" to "Yes".
Regards, Vadim G.
Vladimir_P_1234567890
Hello Arvind,
What sample you are writing about? examples of concurrent hash map usage can be found in getting started and fibonacci examples. Both are available in composer.
--Vladimir
