Software Archive
Read-only legacy content
17060 Discussions
HAXM doesn't work
Maxence_B_
Hello, I use Android Studio and I wanted to use the emulator. I installed HAXM and my error is : /dev/kvm is not found. I tried to install HAXM without Android Studio and I have two errors : - During the installation : Failed to configure driver : unknown error. Failed to open driver. And after Windows says : (I'm French, I translate) Windows has blocked the installation of an numerically unsigned driver . Uninstall the program or device who use use it and search a numerically signed version of the driver on the editor's website. I hope you can help me, thanks a lot.
Jun_H_Intel
Did you meet this on LATEST  Windows 10? if you do, then according to Microsoft (full article here):https://blogs.msdn.microsoft.com/windows_hardware_certification/2016/07/...
To summarize, on non-upgraded fresh installations of Windows 10, version 1607 with Secure Boot ON, drivers must be signed by Microsoft or with an end-entity certificate issued prior to July 29th, 2015 that chains to a supported cross-signed CA. We may fix this on next HAXM release. But unforturnate, right now, you only can try with Secure Boot OFF, maybe that is a work around, if you success, please let us know.
FYI, this issue is also tracked here: https://code.google.com/p/android/issues/detail?id=221594
Cai_H_
the HAXM_Driver security is sha-1 doesn't work in windows 10
Si_Ting_L_
Same problem here;(
Arik_A_
I had same problem before. Enable HW Virtualization in Bios fix my problem
Jun_H_Intel
Maxence_B_
Thank you ! It works with Secure Boot disabled
Jun_H_Intel
Here is the new driver, HAXM v6.0.4, which fixed this issue, released in Android Studio. This will released in Intel developer zone soon. Or you can download it from below link directly to skip install Android Studio: Package is attached in comment in https://code.google.com/p/android/issues/detail?id=221594, in #38 floor comment.
