Software Archive
Read-only legacy content
17060 Discussions
HAXM installation error
Mohammad_A_1
Hello
I'm trying to install HAXM but I get this message every time
This computer meets the requirements for HAXM, but Inter Virtualization Technology (VT-X) is not turned on.
HAXM can not be installed until VT-x is enabled.
I enabled it in my laptop BIOS but still get the same message
is there any thing to enable or do with BIOS or windows?
I have HP EliteBook 6930p
http://www.cnet.com/products/hp-elitebook-6930p-14-1-core-2-duo-p8700-windows-7-pro-xp-pro-downgrade-2-gb-ram-250-gb-hdd-series/specs/
and running windows 7 ultimate
thank you in advance.
apoorv_a_
even i had a similiar problem but in mine i get the message xd is not enabled
Ionel_M_Intel
Check BIOS -> Execute Disable Bit option. Also check on Windows -> System Properties -> Data Execution Prevention. It should work after you enable these options.
