Software Archive
Read-only legacy content
17060 Discussions
HAXM memory setting not updated
Tong_T_
I got an intel processor supporting virtualization technology and is already enabled in BIOS.
I run the HAXM and set memory limit manually and installed successfully.
But the saved memory limit is always the default value 1024 MB.
I run the set up again and change it to even lower limit but it is not saved either.
Anyone got the same issue before??
Thank you!
