Software Archive
Read-only legacy content
17060 Discussions
HLS stream/Ajax/InAppBrowser
antonio_carlos_o_
I need some help,
when using internal browser, hls stream play very well, but can't exec ajax calls, and don't close browser, and with InAppBrowser i can exec ajax calls, can close the browser, can exec executeScript, but hls stream don't play.
any Idea?
            function Kiosk() {
                $("#situacao").html("<center>Acessando o Servidor...</center>");
                var murl = dev.isDeviceReady.url+ 'kiosk';
                var dados = { uuid: dev.isDeviceReady.DeviceUUid,
                              connection:   dev.isDeviceReady.DeviceConnection,
                              platform:dev.isDeviceReady.NavPlatform,
                              model:dev.isDeviceReady.DeviceModel,
                              nr: ++dev.isDeviceReady.nr,
                              idexterno:dev.isDeviceReady.idexterno
                $.ajax({
                    type: "GET",
                    url: murl,
                    data: dados,
                    crossDomain: true,
                    timeout: 3000,
                    contentType: "application/json; charset=utf-8",
                    dataType: "json",
                    complete: function (jqXHR, textStatus) {
                        data = JSON.parse( jqXHR.response );
                        var definido = (typeof data.resp !== "undefined");
                        console.log("responseCode:"+jqXHR.status + ' ' + definido  );
                        if ((jqXHR.status == 200) || (definido)) {
                           $("#situacao").html("<center>" +  jqXHR.statusText+ "</center>");
                           if (data.resp.modo) {
                               $("#situacao").html("<center>" + data.resp.texto + "</center>");
                               if (!dev.isDeviceReady.isShowMessage){
                                  dev.isDeviceReady.isShowMessage = true;
                                  var urlapp = dev.isDeviceReady.url + 'index.html' ;
                                  // with internal browser hls stream play
                                  delete window.open;
                                  // but ajax,close and executeScript fail
                                  dev.isDeviceReady.ref = window.open(urlapp, '_blank', 'location=no');
                                  dev.isDeviceReady.ref.addEventListener( "loaderror", function() {
                                       console.log('loaderror:');
                               } else {
                                 dev.isDeviceReady.ref.executeScript({
                                    code: "sessionStorage.getItem( 'dados' )"
                                 function( values ) {
                                    var name = values[ 0 ];
                                    console.log('180:<<<')
                                    if ( name ) {
                                        name = JSON.parse( name );
                                        console.dir(name);
                           } else {
                                dev.isDeviceReady.isShowMessage = false;
                                if (dev.isDeviceReady.ref)
                                    dev.isDeviceReady.ref.close();
                        } else {
                           $("#situacao").html("<center>  O servidor não conseguiu processar o pedido; Tente novamente mais tarde...</center>");
            Kiosk();
            setInterval(function () {
                Kiosk();
            }, 1000 * 10 );
antonio_carlos_o_
aditional data
using emulation tab, i can't see hls stream, receiveing this message bellow. in debug tab
"Your browser does not support MSE, which is necessary for HTML5 playback.
Flash Fallback is provided only when Viblast is used in combination with video.js. For more info refer to http://viblast.com/player/docs/videojs-integration"
vrs.: 3357/emulation
(Object) { "ACreq": "Mozilla/5.0 (Linux; Android 4.1.1; Nexus 7 Build/JRO03D) AppleWebKit/535.19 (KHTML, like Gecko) Chrome/18.0.1025.166 Safari/535.19", "filename": "./vs/index.html" }
vrs.: 3400/emulation
windows 10/chrome
(Object) { "ACreq": "Mozilla/5.0 (Windows NT 10.0; Win64; x64)                AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.102 Safari/537.36", "filename": "./vs/index.html" }
PaulF_IntelCorp
Most AJAX problems have been due to using the jQuery 1 library. Try switching to the jQuery 2 library, see > https://software.intel.com/en-us/xdk/faqs/app-designer#ajax-jquery-one-fail <
I'm curious, why are adding to the dev.isDeviceReady object? That object is created by the xdk/init-dev.js file and it's only purpose is for combining a few ready events to make it easier to start your app at an appropriate moment. I recommend that you not augment it with additional elements.
Regarding the error messages, it looks like you are trying to play a specially formatted video file? Not sure, But searching for that error message brings up a list of items, including > https://developer.mozilla.org/en-US/docs/Web/HTML/Supported_media_formats <
