Software Archive
Read-only legacy content
17060 Discussions
HTTP Request Failed
Long_V_
I am trying to build a Android Crosswalk project however I get a warning for HTTP request failed.
PaulF_IntelCorp
Can you provide more details. For example, where do you see this message. A screenshot of the message and the context in which it was received. Is this a message during build or during simulation or debug or ???
Long_V_
The error occurs while building the project.
PaulF_IntelCorp
What happens if you try this from another network? For example, if you are on a work network, try it from your home network. Do you have a proxy on your network?
Long_V_
I don't have any other network to choose from, there's no proxy and it used to work a while ago before I reinstalled Windows.
PaulF_IntelCorp
Did you reinstall the XDK with your reinstall of Windows? I've seen some issues where the XDK behaves funny after upgrading to Windows 10, but reinstalling the XDK fixes those issues. Follow these instructions to perform a complete uninstall of the XDK from your system, and then try a reinstall > https://software.intel.com/en-us/xdk/faqs/general#uninstall-xdk
Long_V_
I tried reinstalling but the issue still remains.
PaulF_IntelCorp
Are you able to use the Test tab to push your project to App Center?
See the last item in this FAQ regarding logging into App Center. Can you do that from your browser? https://software.intel.com/en-us/xdk/faqs/general#recover-xdk You may also want to try clearing the XDK program cache directories and files.
Long_V_
I noticed that it only happens for that one project, the app works fine in emulate but won't build or run in test for some reason.
PaulF_IntelCorp
My suspicion is there's an issue with old versions of your app that are "stored" in the App Center. I've seen this before with my account, but never with that error message. Go to the Intel XDK App Center and find the project (or projects) that is causing the problem (you may see multiple entries for one project due to changes in our login system). Find the little trash can icon and use it to delete that project from App Center. I'm guessing that will resolve the problem.
Here's an image of the app center and the trash can icon you need to click:
