Please help guys,
I have developed an app that when I push a button, it takes me to "tvguide", however when I press the home button to go back to the home page, the button i pressed to go to tvguide again is not functioning properly.
By that, I mean, only the top half of the button recognises the tap. Nothing happens if i touch the bottom half of the button.
Its worth noting that the emulator works fine.. only live testing generates this error
This is for IOS
XDK 3088
</head>
<body>
</div>
<div class="upage-content ac0 content-area vertical-col" id="page_86_50">
<div class="uib-button-bar widget uib_w_2 d-margins" data-uib="media/button_bar" data-ver="0">
<a class="uib-graphic-button hover-graphic-button active-graphic-button default-graphic-button default-graphic-text widget uib_w_3 settingsize cursortype d-margins Library-Button media-button-text-bottom" data-uib="media/graphic_button" data-ver="0" id="libraryindexid"
role="button" title="On-Demand Library">
<img aria-hidden="true">
<span class="customcaption" aria-hidden="true">ON DEMAND</span>
</a>
<a class="uib-graphic-button hover-graphic-button active-graphic-button default-graphic-button default-graphic-text widget uib_w_3 settingsize imagesize cursortype d-margins Library-Button media-button-text-bottom" data-uib="media/graphic_button" data-ver="0"
id="tvguideid" role="button" title="TV Guide">
<img>
<span class="customcaption" aria-hidden="true">TV GUIDE</span>
</a>
</div>
<div class="upage-content ac0 content-area vertical-col" id="page_65_75">
<a class="uib-graphic-button hover-graphic-button active-graphic-button default-graphic-button default-graphic-text widget uib_w_22 homesizing homeimage d-margins cursortype media-button-text-bottom" data-uib="media/graphic_button" data-ver="0" id="tvguidehome"
role="button" title="Home">
<img aria-hidden="true" src="images/Home.png">
<span class="customcaption" aria-hidden="true">Home</span>
</a>
<div class="widget uib_w_27 d-margins iframe-size" data-uib="media/iframe" data-ver="0">
<iframe src="http://xxxxxxxx/tv_guide/" id="TV Guide"></iframe>
</div>
</div>
</div>
</div>
</body>
</html>
- Tags:
- HTML5
- Intel® XDK
