Software Archive
Read-only legacy content
17060 Discussions
Hand Gesture not recognized...
Fadi_H_
Hello Guys, i am writing here for the 3rd time, i hope that someone will finally answer my question...
The following java code is working, the hands are recognized BUT the gestures arent!! did i forget anything in the code?
for any helpful hints i would be thankful!
public class handgecogni  {
	public static void main(String s[]) {
	System.out.println("Starting hand tracker.");
	PXCMSenseManager senseManager =PXCMSenseManager.CreateInstance();
	senseManager.EnableStream(PXCMCapture.StreamType.STREAM_TYPE_COLOR,640,480,30);
	senseManager.EnableHand(null);
	PXCMHandModule handModule = senseManager.QueryHand();
	senseManager.Init();
	PXCMHandData handData = handModule.CreateOutput();
	PXCMHandConfiguration handConfig = handModule.CreateActiveConfiguration();
	handConfig.DisableAllGestures();
	// i want to make only thumbs up recognized
	handConfig.EnableGesture("thumbs_up");
	handConfig.EnableAllAlerts();
	handConfig.ApplyChanges();
	PXCMCaptureManager captureMgr = senseManager.QueryCaptureManager();
	captureMgr.FilterByDeviceInfo("RealSense",null, 0);
	pxcmStatus sts = senseManager.EnableHand(null);
	sts = senseManager.Init();
	handConfig.Update();
		if (sts.compareTo(pxcmStatus.PXCM_STATUS_NO_ERROR) >= 0) {
			for (int nframes = 0; nframes < 3000; nframes++) {
		//	System.out.println("Frame # " + );
			sts = senseManager.AcquireFrame(true);
			if (sts.compareTo(pxcmStatus.PXCM_STATUS_NO_ERROR) < 0)
			break;
				while (senseManager.AcquireFrame(true).isSuccessful()) {
				// Retrieve current hand tracking results
				handData.Update();
				PXCMHandData.GestureData gestureData = new PXCMHandData.GestureData();
				PXCMHandData.IHand hand = new PXCMHandData.IHand();
				sts = handData.QueryHandData(PXCMHandData.AccessOrderType.ACCESS_ORDER_NEAR_TO_FAR,0, hand);
					PXCMPointF32 image = hand.QueryMassCenterImage();
					PXCMPoint3DF32 world = hand.QueryMassCenterWorld();
					boolean result = handData.IsGestureFired("thumbs_up", gestureData);
					System.out.print("  Is Thumbs up : (" + result+ ")\n");
					System.out.print("   Image Position: (" + image.x + ","+ image.y + ")");
					System.out.println("   World Position: (" + world.x + ","+ world.y + "," + world.z + ")");
				int ngestures = handData.QueryNumberOfHands();
				System.out.println("# of hands is "+ ngestures);
				senseManager.ReleaseFrame();
		senseManager.close();
Bryan_B_Intel1
Hello Fadi,
Have you tried "thumb_up" instead of "thumbs_up"? There might be a typo here.
-Bryan
Fadi_H_
Hello Bryan, thanx for your comment, i changed it but no difference.  in consloe still showing:   " Is Thumbs up : (false)" also when  place my hand in front of the camera "thumb up"
Bryan_B_Intel1
Just to make sure, did you change it in both places?
-Bryan
Fadi_H_
oops! i changed both now, it seems to work!! thaanks a alot , but its working a weird way, it shows one time true and 10 times false.
its not showing "true" one after the other.
any way i have made this boolean, to check if the gesture recognition is working.
the main purpose of my program is to enable "thumb_up" and "thumb_down" and "swipe"
i will try to make some changes sothat it shows those up written gestures in the console.
thank you again :)
Bryan_B_Intel1
Glad to hear it's moving forward! You may want to refer to para. 4.5.6 on page 1220 in sdkmanuals.pdf (C:\Program Files (x86)\Intel\RSSDK\doc\PDF) for the naming conventions used for the other gestures (e.g., "swipe_left", etc.)
-Bryan
Fadi_H_
now i got it, one last question, i wanted to show in the console the name of the gesture instead of true and false,
i used this    System.out.print("Gesture is \n" +gestureData.name);
it didnt work and showed only "Gesture is" repeatedly
Fadi_H_
Dear Bryan, i found it! i wrote this code and thumb up and down are working now,
				if (handData.IsGestureFired("thumb_up", gestureData)) {
				System.out.println("thumb up!!");
				else if (handData.IsGestureFired("thumb_down", gestureData)) {
					System.out.println("thumb down!!");
				else if (handData.IsGestureFired("wave", gestureData)) {
					System.out.println("wave!!");
for waving im going to use swipe_right and swipe_left because it didnt recognize it
