Software Archive
Read-only legacy content
17060 Discussions
Hardware Back button Event
Puspad_s_
Hello
    I want to track hardware back button event on my app for android. If user press hardware back button from device I want to track this event.
I had tried these below function already but its not working anymore.
document.addEventListener("intel.xdk.device.ready",function() {
    //start grabbing the Android hardware back button
    intel.xdk.device.addVirtualPage();
},false);
document.addEventListener("intel.xdk.device.hardware.back", function() {
    //continue to grab the back button
    document.getElementsByTagName("body")[0].innerHTML += "Hardware back button pressed
}, false);
Currently my app is based on appframework 3.
Anyone has idea how to do it right way?
Thank you!
Elroy_A_Intel
I recommend using the Apache Cordova "backbutton" event instead for tracking when the user presses the Android back button. You can find information at https://cordova.apache.org/docs/en/dev/cordova/events/events.backbutton.html. Currently, the intel.xdk apis are not being maintained for current mobile platform versions.
Ariska_Hidayat
Until now I still can not make a back button. Does anyone know? thx
Pamela_H_Intel
Ariska - Adding a back button differs for different templates. Do you just want to create a back button by hand, or are you using a particular template? If you want backbuttons on a tab view, for example, take a look at the Yoga sample. In the Yoga sample app look at the bottom of the index.html file. The back buttons are enabled when you don't use the clearhistory() function.
Joko_P_
I have the same problem. But when I change theme into device native, or android - light or ios it works. Only when I use App Framework theme backbutton close the app.
