Software Archive
Read-only legacy content
17060 Discussions
Have error again when build the apps
Muhammad_Y_Efendi
I got the same error like two days ago when tried to build the apps.
ERROR (-9) from "client:upload-manager": Error in uploading project files: : Error in uploading project files: : Error in uploading project files: : certificate not trusted; More info: {"upload":"request","method":"PUT","proxy":"yes","url":"https://am-xdk2.s3.amazonaws.com/cust.2f29dbe3-8240-46d8-8b31-fff1be358b68/app.deb6b273-b9e0-49ee-a746-08eaa567914c/a2ec7c7e-78ff-4d20-9fd4-d6d12037abd7/PRODUCTION/plugins.zip?X-Amz-Expires=600&x-amz-security-token=FQoDYXdzEKb%2F%2F%2F%2F%2F%2F%2F%2F%2F%2FwEaDF760bVuEFqQ87HAjyKcAzRDZGuazt13gPfb4ILQJ%2FxS9gJxIrGhJ%2BuREBuGBuE1jQxxnwpf4%2F3Bk0eygvo%2BQAZVZJGCsw311UMnv3ghEU3Pl%2B4sTGSMkUF2iKuVAsUHBooAPlgYMZ6v8Cqa5J126nW%2BXqSjhjCl9zTby2n4D%2F8VgLew9NJlgmStrEiUN5iw3curhG06DdEnRKBuON0wOJpaE3hjS3jP0h4raE%2FfaKCavW%2FMskUIauGrA3B3PMaiqOz9eVjDIOmw5pS2mx7VPgkhg4LCTDqI%2BHkpQ9cMu0ye2DVGxy%2FJRN8AMOc0OTdccf4zK%2Fs3TE95pR9%2FZwPwI%2BYKuwmWPaD3aEmmVvUnSe5K05aQ0vg0gY45vcj48TI1xZKeQPE%2Fwu6Bw7725O8Sgmz5K4bzlsPuFJnA5zD8o%2BMNmbHk8OuA%2FKAdsggzIz5%2FnGg09LzU9RbgxnBmeh4WnDRZDalKmBNBZZvKSQihZzkFjYCT%2BP0a%2Bh4odyaty8p%2FmpY9kZqkBf6f3PpeOf7uacx67rI15mXgPA48TRu%2FWitaZj%2F%2Br3yQydYOHdco5%2BnswAU%3D&X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=ASIAIXEWUH2E46YZVWXQ/20161103/us-east-1/s3/aws4_request&X-Amz-Date=20161103T135614Z&X-Amz-SignedHeaders=content-length;content-md5;content-type;host;x-amz-security-token&X-Amz-Signature=02ec166491002b4c5eb4ebd7077dc06187fe66946cecb24f777fd33e6fa1da25","headers":[{"headerName":"Content-Type","headerValue":"application/zip"},{"headerName":"Content-MD5","headerValue":"74oc8IrwJyhskl+tUyYUMw=="},{"headerName":"Content-Length","headerValue":"177947749"}]} Error at new ComponentError (/Applications/Intel
Could anyone help this issue, please?
PaulF_IntelCorp
Muhammad_Y_Efendi
Thank you, Paul.
I already followed your URL, and It still doesn't work. I have the same error - "Unable to upload the project files"
My version is 3641.
PaulF_IntelCorp
Muhammad -- sending you a private message to see if I can get a copy of your project.
PaulF_IntelCorp
p.s. Are you able to create and build the "hello cordova" sample app?
Muhammad_Y_Efendi
Hi Paul,
The problem was Paypal Cordova Plugin. Once I removed it, and I am able to upload again.
Do you have any experience using Paypal Cordova Plugin? Or maybe other user?
Thank,
PaulF_IntelCorp
Hi Muhammad -- glad you figured out the problem. We have no experience with the Paypal plugin. Inspecting the plugin.xml file, it appears that it relies on an included gradle script, which will fail with our build system. However, that does not explain why you get the error on upload. According to the documentation, it also requires that you download and install the Paypal binary lib files, which can only be done with our system by creating a custom plugin and then importing that into our system.
In essence, using that plugin with out build system is not going to be easy. I recommend you use either Cordova CLI to build your app or use PhoneGap Build. You're running into some limitations in our build system that are not likely to be resolved in the near future.
p.s. I've deleted the message with your attached app.
Muhammad_Y_Efendi
Hi Paul, Thank you so much for your great explanation.
I will figure out how to integrate with Paypal using different way.
