Will XDK change this? Now the project keep in http://appcenter.html5tools-software.intel.com/ and shown in App Preview. Even project that I already remove from XDK. Even worst, if I recreate new project with same name, it will show 2 project with same name in App Preview. This is very confusing and inconvenient.
XDK team please consider make this workflow better. Thanks.
MZ
- Tags:
- HTML5
- Intel® XDK
When you log into the AppCenter website, there is an option to delete the project from the cloud. Click the trashcan icon next to the project name.
when I try to connect to http://appcenter.html5tools-software.intel.com/ me this is displayed:
Thank you for using the Intel® XDK.
If you are ACCESSING AppPreview from this service, you may close the sign in the window.
how do I delete the app into the AppCenter website
thank you
Hi Mark,
This would be the site to access the control panel: https://appcenter.html5tools-software.intel.com/csd/controlpanel.aspx
Is it the same project when pushed twice is showing two different entries on app preview? Or is it different projects that just have the same name? Because if I am not wrong, it differentiates based on the project GUID in your .xdk file. If it is the same project ID, it will replace the app. Else, it will create two different entries.
I had to delete the project on the site to create a new with same name
Please do it ! It is simples and fighting for it is not worth
Keep in mind Intel XDK create app to you just with HTML and not knowing JAVA !!!
[]´s
Marcos
I have to reinforce his complaint. Even when SUPPORT answered here, you guys should already have placed a link (to where we should go and delete the darn files) on your first post. Non sense.
KIKORIO ~
Are you having issues deleting project files?
Kikorio, please see the FAQs page > https://software.intel.com/en-us/xdk/faqs/general#apps-in-development
As we all know , commoning delete is don't delete data from phone premanently , the data is still store in a different way on the phone , the some recovery tool can be recovered them from phone easily , if you want to premanently delete data from phone without recovered, you must to use an erase tool to deeply erase android phopne, in order to avoid some deleted data exposed , the erase is the secured method to protece you privacy data from being leak out ,
Thanks for everyone ..This topic was so helpful for me (:
