Software Archive
Read-only legacy content
17060 Discussions
Help! Cannot upload multiple apk!
Isaiah_L_
Hi folks I'm trying to upload the arm and x86 Crosswalk apk but it's giving me an error message on the play store.
It's telling me that both apk that im uploading support ARM and x86 and so I cannot have both.
Can you look into the builds, that are being compiled please.
The Arm apk has this as its platform support:
arm64-v8a, armeabi, armeabi-v7a, x86, x86_64
The x86 apk has this as it's native platform support:
As you can see they are EXACTLY the same so google won't let me upload them both. Should the ARM crosswalk build have x86 and x86_64 for it's native platform support?
Hamilton_Tenório_da_
Valued Contributor I
Are you using CW 15? Paul (Intel) said to me that there is an issue about it. They are working about it.
Isaiah_L_
Yes, should I use lower version?
PaulF_IntelCorp
Isaiah -- your issue sounds like the problem that Hamilton is referring to. It has been fixed in the Crosswalk 7-14 builds, but is not yet fixed in the Crosswalk 15 builds. So the solution, right now, is to switch to CLI 4.1.2 and build with Crosswalk 14.
