Software Archive
Read-only legacy content
Help My
Khaisar_Java
Congratulations Night intel developer
I name my home khaisarjava Indonesia
I am interested in the article about Sandroid Emulator on Intel
question-I.
1. If my notebook can run android applications if
OS : windows 8.1 Enterprise
Processor : Intel(R) Atom (TM) CPU N550 @ 1.50GHz 1.50 GHz
RAM : 2GB
Type OS : 32
2. What files should I download
3. How way correct installation
for coming down I say many thanks...
JLuna5
The way correct is unistalling w8 and installing ubuntu!
Khaisar_Java
Is there no other solution for example use the emulator...
Alexander_W_Intel
you can use the Android Emulator which is part of the Android SDK. There is a good article on IDZ that explains how to install it: http://software.intel.com/en-us/articles/speeding-up-the-android-emulator-on-intel-architecture. However the article focus on the accelerated Android emulator (Intel HAXM or KVM). For your laptop the accelerated emulator will not work, because your CPU does not support virtualization. Without virtualization you can still use the emulator but it will be much slower.
Hope this helps!
Alex
Andy_F_
@Khaisar Java; I doubt you will be happy with this machine as development machine, as the Android Emulator will used quite a bit of the CPU, as Alexander already mentioned.
