Software Archive
Read-only legacy content
17060 Discussions
Help me please i need this download
luisgon
I cant play games because i need a download and this is my graphics driver
Intel 82865G Graphics and Memory Controller Hub (GMCH)
I have windoes and when i want to download it says i cant download the driver contact the something for everything i try to download on intel
Neal_Pierman
Valued Contributor I
You'll probably need to provide a bit more information before we can help here.
First of all, what is the exact error message that you are seeing (cut/paste from the screen)? It's not clear whether you have a download issue or an install issue, so be sure to attempt the download and install from an admin account.
What is your system configuration, and have you tried downloading from your system vendor's site (as they usually know what are the correct drivers). The drivers may be out-of-date, especially for Intel Integrated Graphics, in which case goto this site and see if Intel believes that your graphics drivers are the latest available. Another option is to goto the Intel downloads site, and search by your specific configuration (chipset, etc.).
Also, it is possible that you are trying to download a driver that is not compatible with your configuration. Therefore, why do you believe that you need a specific download -- is it the game vendor or some other source?
Hopefully this helps... please let us know what else we can do to help.
Neal
safeguardclothing
please check ur Pc specification
rajni
HI Neal, Thanks for your answer. I really appriciate your reply. I have the same problem. Now it's sloved. Thanks again.
