Software Archive
Read-only legacy content
17060 Discussions
Help with layout
Alexandre_S_
I am creating an application and am beginner with Intel XDK , I created the main screen and decided to compile the application. Installed on android 5.1.1 fine, but the android 4.1.2 lose layout. Can someone help me?
Tks for all.
Images: attached.
Anusha_M_Intel1
Check out this FAQ - https://software.intel.com/en-us/xdk/faqs/app-designer#size-ui-elements
Chris_P_Intel
We'd be happy to help.  But we'll need more than just screenshots.  Can you .zip and attach your project?
Also, some questions:
  • Are you using the Design view? Or coding it yourself?
  • If using the Design view, which UI framework did you choose?
  • What is that list of icons on the left? Meaning, what Design view controls were used to construct it? Or what is the HTML/CSS it is built with?
Chris
Anusha_M_Intel1
Alexandre_S_
Thanks for all,
I'm use design view and buttongrid inside a row.
I'll read the FAQ and try another way.
tks.
