Software Archive
Read-only legacy content
17060 Discussions
Help with web Socket jsp.
JLuna5
Nouveau contributeur I
3 614 Visites
Good day, I'm trying to make a web socket with java, it is  as a chat, but I don't find how make this, someone might help me with this?
0 Compliments
14 Réponses
JLuna5
3 614 Visites
Buenos días, estoy tratando de hacer un socket web con Java, es como un chat, pero no encuentro cómo hacer esto, alguien podría ayudarme con esto?
0 Compliments
Alexander_W_Intel
3 614 Visites
your question is a little bit unclear. Do you want to write a pure chat application or more something like a messenger. For a messenger I think using the Google Cloud Messaging for Android(GCM) makes most sense. With GCM it is not required to poll for new messages or hold a TCP connection open all the time. You find more information here: http://developer.android.com/google/gcm/index.html . I don't know if GCM would be also the first choice for a chat application.
For writing a chat application there are nice small examples including source code like that one here: https://code.google.com/p/simple-android-instant-messaging-application/ . There are also very easy to use XMPP libraries available that handles all the networking stuff for you. One example is Smack API: http://www.igniterealtime.org/projects/smack/index.jsp
Hope this helps,
Alex
0 Compliments
JLuna5
3 614 Visites
Hi Alexander Weggerle,
Thank you for suggestion, I'm trying to make a web socket with html and jsp, is for work in real time, when you do some on an app, if I have the same app and permissions, I will see this change on app in time real.
0 Compliments
Alexander_W_Intel
3 614 Visites
so you mean you want to use HTML5 web sockets on the client side (Android) and Java Server Pages(JSP) on the server side?
Alex
0 Compliments
JLuna5
3 614 Visites
Not initially think it will be both client and web server, android not yet.
Thanks you!
0 Compliments
Ashwin_S_Ashok
Débutant
3 614 Visites
so you are trying to do it in java..?
0 Compliments
JLuna5
3 614 Visites
Hi Ashwin, I have tried make an app that refresh on time real in each user of same app, the changes doing for the other user, like a chat.
0 Compliments
Alexander_W_Intel
3 614 Visites
just some more suggestions which might help you to write your application.I think I found a very sample using JSP for a chat application: http://ben-bai.blogspot.de/2012/01/jsp-practice-simple-chat.html .
I think you should also consider to use node.js instead of JSP. It is easier to use especially for html5 projects. There is a nice tutorial here: http://net.tutsplus.com/tutorials/javascript-ajax/real-time-chat-with-nodejs-socket-io-and-expressjs/
If you want to extend your chat for audio and video you can use WebRTC for your application. There is a really nice GoogleIO Talk about it and here is a getting started guide
I hope this helps you!
Alex
0 Compliments
JLuna5
3 614 Visites
Hi Alexander, thank is very util your information, webRTC is a good option for my app, thank you! and if you know about some as chat rooms how make this with node js, express, socket io and session I will be grateful with you!
0 Compliments
Alexander_W_Intel
3 614 Visites
do you have any specific problem you are facing at the moment? It's hard to help if I don't know where you are with your development at the moment :-).
Alex
0 Compliments
JLuna5
3 614 Visites
Hi Alexander,I need to apply to node js mvc.
0 Compliments
Alexander_W_Intel
3 614 Visites
I never used a MWC framework with node.js. But this one looks very promising: http://sailsjs.org . It has a nice documentation. Does this help you?
Alex
0 Compliments
JLuna5
3 614 Visites
Thnank you Alexander for you attention!
0 Compliments
Neeraj_R_
Débutant
3 614 Visites
  Hi Alexander,
     Did JSP having SOCKETS?
Actually i am having a task in my company regarding chat application(one-one, one-two many). It is not company related task to test my effecicency but i am a fresher. so, i opted for Jsp (socket).
If it possible how to build such project. Please help me. Thanks in Advance
0 Compliments
Répondre
