Software Archive
Read-only legacy content
17060 Discussions
How To Make Installer with Realsense Runtime?
Ariska_Hidayat
Hi All,
I am a game developer with realsense. After the game finished, I wanted to create an installer. but when installed on another computer, the game can not be executed because there is no realsense runtime on the computer. My question, how when installing a game realsense by installing the  realsense runtime if not done there? thx
Xusheng_L_Intel
You need include the RealSense runtime in your app package. You can find detail info @https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?deploy_application_deployment.html
Ariska_Hidayat
Does runtime installed just insert the file :
$(RSSDK_DIR)/bin/win32:
libpxcclr.unity.dll
libpxccpp2c.dll
libpxccpp2c.dll.signature
$(RSSDK_DIR)/bin/x64:
libpxcclr.unity.dll
libpxccpp2c.dll
Or do I have to do something else? thx.
Ariska_Hidayat
I've found the solution of my problem:
https://software.intel.com/en-us/articles/add-realsense-runtime-to-app-installer
Hope it is useful.
Sankalp_S_
Hello Ariska,
Are you using unity for your development ? If yes then can you guide me how to combine exported scripts from realtime installer and my exe file made from unity.
I am using inno installer for combine both package but in documents they are telling to follow the commands of readme_cmd.txt.  What does that means ?
Waiting for your help.
Ariska_Hidayat
Hi Sankalp,
Yes, I'm using Unity for Development n using inno for make installer.
You must  follow the commands of readme_cmd.txt. You must use a string was in readme_cmd.txt as a parameter in Inno Script.
example parameter on inno script:
[Run]
Filename: "{app}\runtime\setup.exe"; Parameters:"setup.exe --silent --no-progress --acceptlicense=yes --fnone=all --finstall=core,vs_rt_2012,hand,personify,vs_rt_2013,face3d,utils,lanternrock";
Maybe parameters in your application may be different from the parameters in my application. You should check the parameters in the file readme_cmd.txt. I hope this can help you. thx.
