Software Archive
Read-only legacy content
17060 Discussions
How can I use appframework UI with jQuery and jQuery.Validate?
Jim_A_1
Dear XDK experts,
I created a AppFramework project with intel XDK (ver. 1912), and created one button with click event via the app designer. The following js code is created in the index_user_scripts.js file. The code works fine. When I click the button, the alert pops up. However, when I uncommented the initValidation() in the event_handlers(), the click event won't work and I will get error messages saying jquery is not defined. I doubled checked the include path and verified the jquery js file is in the js folder (I downloaded and saved in the js folder). I have shown the index_user_scripts.js, the header of the index.html file and the error message below. Any help will be greatly appreciated. I have searched online and some said jquery and appframework UI cannot be used together. Is it still true?
BTW, does appFramework has built-in ability to do form validation? Is jquery.validate the best for form validate? If not, which one is the best for a xdk project? Thanks!
//===== Content of the index_user_scripts.js file =====//
(function()
 "use strict";
   hook up event handlers
 function register_event_handlers()
    initValidation();
     /* button  Button */
    $(document).on("click", ".uib_w_2", function(evt)
        /* your code goes here */
        alert("Button is clicked.");
 document.addEventListener("app.Ready", register_event_handlers, false);
function initValidation()
    $("#loginForm").validate
            rules:
                txt_login_email:
                    required: true,
                    email: true
            ,messages:
                txt_login_email: "Please enter a valid email address"
//======= index.html header =========//
        <script src="cordova.js" id="xdkJScordova_"></script>
        <script src="js/app.js"></script>
        <!-- for your event code, see README and file comments for details -->
        <script src="js/init-app.js"></script>
        <!-- for your init code, see README and file comments for details -->
        <script src="xdk/init-dev.js"></script>
        <!-- normalizes device and document ready events, see file for details -->
            You may substitute jQuery for the App Framework selector library.
            See http://app-framework-software.intel.com/documentation.php#afui/afui_jquery
        <script type="application/javascript" src="app_framework/2.1/appframework.js"></script>
        <script type="application/javascript" src="app_framework/2.1/appframework.ui.js" data-ver="1"></script>
        <script src="js/jquery-1.1.1.js"></script>
        <script src="js/jquery.validate.min.js"></script>
        <script type="application/javascript" src="js/index_user_scripts.js"></script>
//====== Error messages after include the jquery.js ======//
Uncaught ReferenceError: jQuery is not defined jquery.validate.min.js:4
Failed to load resource: the server responded with a status of 404 (Not Found) http://127.0.0.1:58889/http-services/ui-builder/web/unit_tests/utils/test_styleparsing.css
Hamilton_Tenório_da_
Valued Contributor I
You can´t use appframework.js and jquery.js.
You need to change the order of the lines and the name of the second one. I use:
<script type="application/javascript" src="js/jquery-2.1.3.js"></script>
<script type="application/javascript" src="js/jq.appframework.min.js"></script>
<script type="application/javascript" src="js/appframework.ui.js"></script>
<script type="application/javascript" src="js/jquery-ui.min.js"></script>
And it works well.
Jim_A_1
Thanks! I tried to include js/jq.appframework.min.js and js/appframework.ui.js after I downloaded them from github, but it still does not work. However, after I use the jquery-2.1.3 instead of 1.1.1, it works perfectly! Thanks so much for your help!
