Software Archive
Read-only legacy content
17060 Discussions
How correctly to use Parallel Inspector?
max-divulskiy
Good afternoon.
Can You prompting why Parallel Inspector shows memory leak in a following example?
[bash]#include "stdafx.h"
#include
#include
#include
class SimpleSum
	float* my_a;
public:
	float sum;
	void operator( )( const tbb::blocked_range& r )
		float *a = my_a;
		for( size_t i=r.begin(); i!=r.end( ); ++i )
			sum += a;
	SimpleSum( SimpleSum& x, tbb::split ) : my_a(x.my_a), sum(0) {}
	void join( const SimpleSum& y )
		sum += y.sum;
	SimpleSum(float a[] ) :
	my_a	(a),
	sum		(0)
int _tmain(int argc, _TCHAR* argv[])
	UINT	Size = 1000;
	float*	Mass = (float*) _aligned_malloc(Size * sizeof(float), 16 );
	for (UINT i = 0; i < Size; i++)
		Mass = (float) i;
	SimpleSum sf( Mass );
	parallel_reduce( tbb::blocked_range(0, Size), sf );
	printf("Result: %f\n", sf.sum);
	_aligned_free( Mass );
	return 0;
Errors (level mi4):
ID Problem Sources Modules Object Size State
P1 Memory leak parallel_reduce.h TBB_reduce.exe 140 Not fixed
P2 Memory leak parallel_reduce.h TBB_reduce.exe 40 Not fixed
P3 Memory leak parallel_reduce.h TBB_reduce.exe 40 Not fixed
P4 Memory leak parallel_reduce.h TBB_reduce.exe 40 Not fixed
P5 Memory leak parallel_reduce.h TBB_reduce.exe 140 Not fixed
P6 Memory leak parallel_reduce.h TBB_reduce.exe 60 Not fixed
P7 Memory leak parallel_reduce.h TBB_reduce.exe 40 Not fixed
P8 Memory leak parallel_reduce.h TBB_reduce.exe 40 Not fixed
P9 Memory leak parallel_reduce.h TBB_reduce.exe 112 Not fixed
P10 Memory leak parallel_reduce.h TBB_reduce.exe 56 Not fixed
P11 Memory leak parallel_reduce.h TBB_reduce.exe 56 Not fixed
P12 Memory leak parallel_reduce.h TBB_reduce.exe 56 Not fixed
P13 Memory leak parallel_reduce.h TBB_reduce.exe 56 Not fixed
P14 Memory leak parallel_reduce.h TBB_reduce.exe 84 Not fixed
P15 Memory leak parallel_reduce.h TBB_reduce.exe 56 Not fixed
P16 Memory leak parallel_reduce.h TBB_reduce.exe 56 Not fixed
P17 Memory leak task.cpp tbb_debug.dll 28 Not fixed
[/bash]
Vladimir_T_Intel
Please, specify which version/build # of Parallel Inspector you were using.
max-divulskiy
Intel Parallel Inspector Update 2, (build 75522)
Inspector. parallel_reduce Inspector TBB- . parallel_for pipeline . . Inspector, parallel_reduce .
Notebook MSI GT740
Core i7 Q720
Windows 7 x64
Visual Studio 2008 v.9.0.30729 + Sp1
Inspector-, i7, .
Vladimir_T_Intel
Inspector'. .
