Software Archive
Read-only legacy content
17060 Discussions
How do you launch the program?
Mike_W_2
I have installed the intel XDK program and have an icon on my screen. When I click on the icon I only get an option to repair or uninstall. How do you launch it?
Amrita_C_Intel
Try repair and see if it works or try uninstalling it because installing process might have interrupted.
Mike_W_2
I have done that at least a dozen times in the last 2 days, I have uninstalled and reinstalled at least a dozen times. I have submitted a ticket only to get the answer visit the forums for help. Very disappointing customer service from Intel.
PaulF_IntelCorp
See the FAQs for a method to completely uninstall and re-install. Also, are you installing on Windows XP? The product will not work properly on XP, must be Windows 7 and above. See Q27 on this page: https://software.intel.com/en-us/xdk/faqs/general
Also, there is an obscure bug that causes the XDK to not run if the "global-settings.xdk" file is corrupt. If that is what is causing this problem, you'll want to ignore the part in the instructions about making a copy of that file.
Mike_W_2
I'm on windows 8
PaulF_IntelCorp
Mike, did you try the complete uninstall procedure that I pointed to? And did you also try deleting the global-settings.xdk file?
Mike_W_2
No. I have no idea what all this stuff is
then:
> cd %LocalAppData%\Intel\XDK
> del *.* /s/q
then:
> cd %LocalAppData%\XDK
> copy global-settings.xdk %UserProfile%
> del *.* /s/q
> copy %UserProfile%\global-settings.xdk .
then:
Swati_S_Intel1
Can you do the following?
1. press Windows Start button.
2. On top right press search icon.
3. Type Intel XDK in the search box.
Do you see Intel XDK in the drop down (with blue icon)?
If so, click on it and it will launch the XDK.
To create a launch shortcut on your desktop, right click on Intel XDK and choose "pin to taskbar" option
If you do not see Intel XDK in the drop down, please let me know.
Swati
