Software Archive
Read-only legacy content
17060 Discussions
How to ALLOCATE memory aligned on 32-byte boundary
michael-a-carr
How can I ALLOCATE an array so that it aligned with a 32-byte boundary? I need to do this for optimum performance when calling Intel's vectorized math libraries...
thanks!
You can't specify alignment with ALLOCATE. Best I can recommend is to malloc n+32 bytes, add 31 to the base address and then AND off the low five bits. Assign this to an integer POINTER for your array pointer. Don't forget to save the original allocated address for the free/
Steve
