Software Archive
Read-only legacy content
17060 Discussions
How to achieve IR Rawstream data at 200 FPS via SDK in C#
Dollaporn_A_1
I use SR300 camera model. I try to get IR Rawstream data at 200 FPS via SDK in C#. In SDK, I can access only Y16 640*480*30 or Y16 640*480*60. However, I found that librealsense has a capability to achieve Y16 640*480*200. How can I get this information? Do you have any suggestion about the solution?
Thank you for your kindness
Johannes_V_
How fast is your current implementation? Can you give code where you measure this?
Dollaporn_A_1
Thank you for your reply. Johannes.
Now, I use 60FPS that I use SDK of realsense (DF_Rawstreams.cs).
The code that it provides:
public Timer()
            QueryPerformanceFrequency(out freq);
            fps = 0;
            QueryPerformanceCounter(out last);
        public void Tick(string text)
            long now;
            QueryPerformanceCounter(out now);
            fps++;
            if (now - last > freq) // update every second
                last = now;
                EventHandler<UpdateStatusEventArgs> handler=UpdateStatus;
                if (handler!=null) handler(this, new UpdateStatusEventArgs(text+" FPS=" + fps));
                fps = 0;
Thank you for helping me
