Software Archive
Read-only legacy content
17060 Discussions
How to change the transition speed of Side Menu or completely remove it
Vijay_R_1
Is it possible to change the transition speed of side menu or remove it. It lags in older devices.
Version: App Framework 2.2
Barry_Johnson
You can set: $.ui.transitionTime which is used by $.ui.toggleLeftSideMenu. $.ui.toggleRightSideMenu takes the transition time as a third parameter.
Vijay_R_1
Awesome. Works perfect.
Thank you.
Barry_Johnson
Great. Glad it worked!
