Software Archive
Read-only legacy content
17060 Discussions
How to compile cilk plus runtime source with Intel® C++ Composer XE 2013
Yaqiong_P_
Dear all,
I want to compile cilk plus runtime source with Intel® C++ Composer XE 2013. I build the cilk plus runtime according to the directions in the "readme" file (libtoolize; aclocal; automake --add-missing; autoconf; ./configure; make; make install). But in this way, gcc is used by default.
Please, could somebody give me some guidelines in order to compile cilk plus runtime source with Intel® C++ Composer XE 2013?
Thanks a lot for your help.
Yaqiong Peng
Hansang_B_Intel
You will be able to use icc/icpc by setting environment variables, CC/CXX, just before invoking "configure".
