Software Archive
Read-only legacy content
17060 Discussions
How to control cursor by hand?
CLi37
The cursor was enabled in Windows main program, hand operations were worked in a thread. I try to apply hand coordinate to control the moving of cursor by PostMessage but there was no reaction. What is wrong? RealSense looks enabled mouse and keyboard at the same time.
CLi37
Thanks for your reference. I do use SetCursorPos. Now I can make cursor follow hand image moving.
My current question is:
What is the best way to select/capture an object at current cursor with gesture?
Anything like XBox to select an object on the screen by hand gesture?
Eusebiu_M_
For .NET you can use http://msdn.microsoft.com/en-us/library/system.windows.forms.cursor.position(v=vs.110).aspx
The problem is that stability of the returned joint position is poor - so expect for the mouse cursor to have an unstable behavior.
CLi37
I have found the similar performance problem. When I enabled joint position function the response speed was slowed down.
A little bit funny thing is that the cursor will be shaking while my hand was not completely stand by still. This is a kind of visual glitch of gesture cursor.
