Software Archive
Read-only legacy content
17060 Discussions
How to debug a library used by a program in the offload section?
Tam__My
Hi!
I want to debug my library which my program uses in the offload section.
1. I tried to use library with debugging information. ​I use the following command line to build the library:
:: set environment call D:\Intel\compilers_and_libraries\windows\bin\compilervars.bat intel64 :: compile icl /Qmic -c -g -Wall -Werror -fpic mylib/*.cpp -lm icl /Qmic -g -shared -o libmylib.so *.o
The size of the library tells me that the debugging information is included in it. When I'm try to debug a program (I use VS 2015 and Intell Parallel Studio 2017), the debugger does not go inside a library.
2. I tried to use the library source files for debugging, but I can't compile a program.
Simple example:
main.cpp
#pragma offload_attribute(push, target(mic)) #include "nativelib.h" #include <iostream> #pragma offload_attribute(pop) int main(int artc, char* argv[]) { #pragma offload target(mic) { std::cout << someFunc(3, 5); } return 0; };
nativelib.h
#ifndef nativelib_h__ #define nativelib_h__ int someFunc(int, int); #endif
nativelib.cpp
#include "nativelib.h" int someFunc(int a, int b) { return a + 2 * b; };
And it lead to link error: "undefined reference to `someFunc(int, int)' ". Of course I can only use header files, but this is not a very nice option.
Please tell me what I'm doing wrong in the above options or explain another version of the debugging the library used in the offload section.
