Software Archive
Read-only legacy content
17060 Discussions
How to get human-readable plain-text output?
kcc
How do I get a human-readable plain-text output from the inspector?
The docs say "insp-cl.txt - Summary information that includes the total number of problems found and types of problems found".
I also found an xml-like file with .pdr extension which contains the full report.
But no sign of a full report in plain text.
David_M_Intel3
Quoting - kcc
The Parallel Inspector command line is designed to be used for regression testing. The thought is that you will want to use the interactive interface as you review the reports. After you define a suppressions file, the use of the command line will enable you to quickly see if there are any regressions between one run and another.
-David
kcc
So, the short answer is "you can't"...
