Software Archive
Read-only legacy content
17060 Discussions
How to get input value - Ionic Framework
Mario_R_
Débutant
7 456 Visites
Hello to all,
using Ionic I can not get the values of the inputs. Precisely I always get "undefined".
Excuse the banal question, but I tried some ways unsuccessful. Someone could explain to me how to do?
I created two simple elements, a text input and a button
HTML code
<button class="button widget uib_w_107 d-margins" data-uib="ionic/button" data-ver="0" id="btn_test" >Get input value</button>
<label class="item item-input widget uib_w_168 d-margins" data-uib="ionic/input" data-ver="0" id="input_text">
   <span class="input-label">Text</span>
   <input type="text" placeholder="bla bla">
</label>
JS code
console.log(document.getElementById("input_text").value); //undefined
console.log($("input_text").val()); //undefined
Thereafter I would empty the input text. Thanks for the help.
0 Compliments
Hamilton_Tenório_da_
Précieux contributeur I
7 456 Visites
Try to give an id to input line, like this:
 <input id="myField" type="text" placeholder="bla bla">
and use this name on
 console.log($("#myField").val());
Voir la solution dans l'envoi d'origine
3 Réponses
Elroy_A_Intel
Employé
7 455 Visites
Since the input is actually in the label element you can try the following line of code to set of the value of the input element:
document.querySelectorAll("#input_text>input")[0].value = "car".
In order to get the value of the input, you can use
For more information on querySelectorAll, visit http://www.w3schools.com/jsref/met_document_queryselectorall.asp
0 Compliments
7 457 Visites
Mario_R_
Débutant
7 455 Visites
Thanks for answers.
In fact the problem was with the id.
App Designer with Ionic puts id inside the div label instead of div input.
// Before
</label>
// After
<label class="item item-input widget uib_w_168 d-margins" data-uib="ionic/input" data-ver="0" >
    <input type="text" placeholder="bla bla" id="input_text">
</label>
Now it works well
console.log(document.getElementById("input_text").value); //Real value input!
Thank you, solved!
0 Compliments
Répondre
