Software Archive
Read-only legacy content
17060 Discussions
How to hide iOs statusbar?
Konstantin_R_
Hi!
On android and wp8.1 statusbar is hide. But I do not understand how to hide the status bar on the iPhone 4s with ios 8.
When i export  cordova project from Construct 2 then i select "hide statusbar". In XDK 2548 (try CLI 4.1.2 and 5.1.1.) I install cordova statusbar plugin and select "fullscreen" in Build settings,  when I test on device - the statusbar is transparent but statusbar icons is visible (like the picture in the attachment). How to hide the ios statusbar completely?
I would be grateful for any help.
Konstantin_R_
please tell me how can I solve this problem?
PaulF_IntelCorp
Please use the Status Bar plugin.
Konstantin_R_
Thank you Paul, but this not work for me. But Corey C  told me the solution, and it helped me:
Corey C. wrote:
Within Construct 2, on the start of your first layout, try adding the Browser's "Execute Javascript" action and execute "StatusBar.hide();"
You will need to make sure you add the StatusBar plugin from within Intel XDK.
Bani_M_
Whats the meaning of "adding the Browser's "Execute Javascript" action",
thanks
B.M.
Jason_B_4
You need to add a Browser object. Then add an action called "Execute Javascript". In that action you type the JavaScript code you need. In this case "StatusBar.hide();"
