Software Archive
Read-only legacy content
17060 Discussions
How to improve real-time performance of i5 6440EQ?
Stephen_S_
Hi guys we faced a problem. During the application of EtherCAT Bus TECH in 32-bit win8.1, we found that 6 Generation Skylake CPU (i5 6440EQ) showed very bad real-time behavior, under the premise that the behavior of 4 Generation Haswell CPU (i5 4570S) was much better. We tried many methods in BIOS such as disable C1E, Speed Step, Hyper-threading and some other USB options, however the results are still disappointing.
Our suppliers suggested that maybe it was a good solution to get the real-time Pacth for PCH and integrated this block with BIOS. However, no documents were found about how to finish this job. Has Intel ever opened the access to real-time Pacth for PCH or were there any examples using this kind of method? And any suggestions to solve this problem? Thank you in advance!
Harold_G_Intel
H,
I saw your thread in communities.  Here is link for Design Center:
http://www.intel.com/content/www/us/en/design/resource-design-center.html
Regards, Hal
Intel(R) Developer Zone Support
https://software.intel.com
*Other names and brands may be claimed as the property of others.
gaston-hillar
Valued Contributor I
Stephen,
What operating system are you using?
