Software Archive
Read-only legacy content
17060 Discussions
How to make a SQL Server Database Connection on Intel XDK?
Joao_V_
Hello, I have project and I only need a SQL Server Connection to finish it, how can I do?
Diego_Calp
Valued Contributor I
The way to do this is use a REST interface to MS SQL and make ajax calls to query the database.
One option is dreamfactory.com, unfortunately it is no longer free for MS SQL. I use it a lot with MySQL and XDK and works great.
Searching for alternatives, I found sandman2, I don't know it but seems promising:
sandman2 automagically generates a RESTful API service from your existing database, without requiring you to write a line of code. Simply point sandman2 to your database, add salt for seasoning, and voila!, a fully RESTful API service with hypermedia support starts running, ready to accept HTTP requests.
https://github.com/jeffknupp/sandman2
It is python, so you need a server with it.
Sorry for not give you more help, I'm not using MS SQL databases, but these could be the starting point to you for research.
Diego
