Software Archive
Read-only legacy content
17060 Discussions
How to make a loading for wait delay radio streaming
Adam_Suchi_Hafizulla
Hi.
Now i have a project to make radio streaming apps with HTML5 Intel XDK, but my problem is when i click play button, its have delay for the radio sound out. I want to ask, how to make a loading information for waiting that delay? When the radio sound out, then the loading dissapear.
Thank you before.
Diego_Calp
Valued Contributor I
Yes, with the events you may show a waiting indicator.
But, I take again a look to your sample code. Try changing preload="auto" to preload="none"
I did an app that plays mp3 files (no live) and this help to reduce the time to start.
Remove autobuffer property, is not used anymore.
"autobuffer attribute | autobuffer property
Use the preload element instead. The autobuffer property was initially listed in the W3C spec, but has been dropped."
Diego
Diego_Calp
Could you post the lines of code that calls the play button to start the radio streaming?
Diego
Diego
I use <audio> tag for the streaming, and javascript audio.play() to play the radio.
<audio autobuffer preload="auto" id="RadioPlayer">
<source src="http://link_streaming/;stream.mp3" type="audio/mp3">
Your browser does not support the audio element.
</audio>
//Button
 <a onclick="radioPlay()" id="btnPlay"><img src="images/btnPlay.png" width="36" height="36"></a>
//Javascript (in other file)
function radioPlay(){
    var audio = document.getElementById("RadioPlayer");
    audio.play();
Diego_Calp
Look for html5 audio tag events, here is some information:
http://stackoverflow.com/questions/8059434/how-do-you-check-if-a-html5-audio-element-is-loaded
Not much time now for an example, post again if you can't find a solution.
Diego
http://stackoverflow.com/questions/8059434/how-do-you-check-if-a-html5-a...
Diego
Thank you before, so there is have a event to check the sound of <audio> is out? Because when user click play button, there is have a delay about 15-45 second before sound of radio can hear.
Diego_Calp
Diego
Diego
Thank you :)
