Software Archive
Read-only legacy content
17060 Discussions
How to make static listening ports
Dave_A__from_Lifeboa
Customer writes:
We have installed the Intel C++ and Fortran Composer XE 2011 and have successfully got thelicenses to float across all our host(s). I also configured the firewall to allow the port(s) itslistening on. The only problem is, when the license host gets rebooted the INTEL listeningdaemon chooses a different port, the Intel license manager daemon stays the same 28518:
[wgoodman@g2-blsb020 ~]$ sudo netstat -tpln | grep -i intel
tcp 0 0 0.0.0.0:28518 0.0.0.0:* LISTEN 4931/lmgrd.intel
tcp 0 0 0.0.0.0:34861 0.0.0.0:* LISTEN 4932/INTEL
But the INTEL daemon (34681) changes every time the system is rebooted. My question is:Is there a configuration file that I can set this to be static? Meaning stays the same after reboot?
Any help would be appreciated,
Thanks.....Dave A. from Lifeboat Distribution
Feilong_H_Intel
Hi Dave,
You could specify a particular port number in VENDOR line, like this, in your license file. That will not invalidate your license file. Please let me know if you have further question.
VENDOR INTEL port=1234
Thank you.
Feilong H.
Intel Developer Support
Tools Knowledge Base: http://software.intel.com/en-us/articles/tools
Thank you Feilong, I'll relay to my customer and let you know how they make out.
Thanks....Dave A. from Lifeboat Distribution.
Worked great...thank you !!!!!
Dave A.
Feilong_H_Intel
Dave,
I'm glad to hear that. Cheers!
Feilong
